Frequency Synthesizer 的使用问题
用DCM中的Frequency Synthesizer 产生7倍频,请问如果我只用CLKFX的话是不是Feedback项可以选NONE就能保证锁定7倍频后的相位?谢谢大家~~~
这是从文档中摘的一句话,不知道理解的对不对 Frequency synthesis always requires some form of clock feedback. However, the DFS unit has an internal feedback loop based on CLKIN and does not require a separate loop on CLKFB if used without the DLL unit.
Feedback Required? No. Uses internal feedback based on CLKIN. Optionally can use CLKFB input if required for Delay-Locked Loop (DLL) functions.
