[求助]:劳请指点程序中的问题 请教:节选相关部分如下: 问题是:编译无法通过。提示:Mapping a total of 103 equations into 8 function blocks........................................................ERROR:Cpld:892 - Cannot place signal count_16<0>. Consider reducing the collapsing input limit or the product term limit to prevent the fitter from creating high input and/or high product term functions. See the fitter report for details. ERROR:Cpld:868 - Cannot fit the design into any of the specified devices with the selected implementation options. ERROR: Fit failed Reason: Process "Fit" did not complete. 如果process1中去掉reghz <= databus(15 downto 0);动态设置reghz值,实现固定分频,成功。如果process1不动,而process2中if( count_16 = reghz )THEN 改为if( count_16 = 12500 )THEN 与固定值比较编译也能通过。
process ( rst,we,enhz ) --复位信号,写信号,cpu控制频率的片选信号 begin if ( rst = RST_ACTIVE ) then reghz <= X"30d4"; ----------复位赋初值 elsif ( we 'event and we = HIGH_ACTIVE ) then if( enhz = LOW_ACTIVE ) then reghz <= databus(15 downto 0);----动态改变分频值 end if; end if; end process;
process(clk)-----40M晶振时钟count_16为16位计数器,st_ad为分频输出信号 begin if( clk'EVENT AND clk='1' )THEN if( count_16 = reghz )THEN count_16 <= X"0000" ; else count_16 <= count_16+'1'; end if;
if( count_16 < 6250 )then st_ad <= '1'; else st_ad <= '0'; end if; end if ; end process; |
