[求助]用什么软件可以把VERILOG的原代码转换为VHDL??
有是有,不过劝你别用,因为错误太多,一般编译不过去的。
如果真想要,就找我 |
感觉也是这样,就像用翻译软件翻译英语一样,得到的总是莫名其妙的东西! |
Error: Top-level design entity "pci" is undefined
源代码是用VERLOG写的 结果出现了这样的问题 编译通不过(只有这一个ERROR)
可能是什么原因呢? |
代码呢?VERLOG里面因该没有entity 什么事情的 |
只有两百多行如果哪位高手有时间能帮我改写成VHDL的小弟请吃饭 |
把我自己根据这个写的VHDL的也上传上来吧,很多错误阿,都晕死了 |
RT 请求帮助 源代码是我在别的地方看到的,总有些问题,后来用翻译的软件,果然错误奇多。现在请大家帮忙看看哪里有错阿,能有时间帮我写成VHDL的就更好了,我自己写的在后面麻烦大家了
[此贴子已经被作者于2006-6-1 17:18:41编辑过] |
module pci ( // PCI ports -- do not modify names! AD, CBE, // PAR, FRAME_N, TRDY_N, IRDY_N, STOP_N, DEVSEL_N, IDSEL, RST_N, PCLK, INTR_N, //PCI Interrupt output Low level active
//LOCAL Signals RD_EN, WR_EN, ADDR, P_L_DA, L_P_DA, INT //local Interrupt, high level active );
inout[31:0]AD; input [3:0]CBE; //inout [3:0] CBE; input FRAME_N; //inout FRAME_N; output TRDY_N; inputIRDY_N; output STOP_N; output DEVSEL_N; input IDSEL; input RST_N; input PCLK; output INTR_N;
output RD_EN; output WR_EN; output [4:0] ADDR; input [31:0] L_P_DA; output [31:0] P_L_DA; input INT;
`define state parameter
`state S_IDLE_S = 2'B00; `state S_BUSY_S = 2'B01; `state S_DATA_S = 2'B10; `state S_STOP_S = 2'B11;
reg [1:0] current_state,next_state; reg CFG_EN; //CFG_EN = 1 : PCI config read/write, CFG_EN = 0: PCI Mem Read/Write reg S_DATA_REG; reg HIT; reg S_RD,S_WR; reg [11:0] BAR0_REG; //{BAR0_REG,20'h00}: 1M PCI MEM Space,last 20 bit is hardware as 0 reg [4:0] ADDR; reg S_DATA; reg [31:0] AD_D;
wire TRDY,STOP;
//State Machine always @(posedge PCLK or negedge RST_N) begin if (~RST_N) current_state <= 2'b0; else current_state <= next_state; end
always @(FRAME_N or IRDY_N or HIT or TRDY or STOP or IRDY_N or current_state ) begin next_state = current_state; case (current_state) S_IDLE_S: if (!FRAME_N & !HIT) next_state = S_BUSY_S; S_BUSY_S: begin if (FRAME_N & !HIT) next_state = S_IDLE_S; else if ((!FRAME_N || !IRDY_N) & HIT) next_state = S_DATA_S; end S_DATA_S: if (FRAME_N & !TRDY) next_state = S_IDLE_S; else if (~STOP) next_state = S_STOP_S; S_STOP_S: if (FRAME_N) next_state = S_IDLE_S; default: next_state = S_IDLE_S; endcase end
//address compare with BAR0 wire #1 AD_EQ = (AD[31:20] == BAR0_REG); //BAR0 Support 1M MEM Space (but littlr PCI CORE only support // 5bit (32byte) Mem Space)
always @(posedge PCLK or negedge RST_N) begin if (~RST_N) begin S_WR <= 1'B0; S_RD <= 1'B0; CFG_EN <= 1'B0; HIT <= 1'B0; //BASE HIT, CFG HIT ADDR <= 5'H0; end else if (!FRAME_N && (current_state == S_IDLE_S)) begin ADDR <= AD[4:0]; //littlr PCI CORE only support 5bit (32byte) Mem Space casex ({CBE,IDSEL}) 5'B0110X: begin S_WR <= 1'B0; S_RD <= 1'B1; //PCI MEM Read CFG_EN <= 1'B0; if (AD_EQ) begin HIT <= 1'B1; end end 5'B0111X: begin CFG_EN <= 1'B0; S_WR <= 1'B1; //PCI MEM Write S_RD <= 1'B0; if (AD_EQ) HIT <= 1'B1; end 5'B10101: begin CFG_EN <= 1'B1; S_RD <= 1'B1; //PCI CFG Read S_WR <= 1'B0; HIT <= 1'B1; end 5'B10111: begin CFG_EN <= 1'B1; S_RD <= 1'B0; //PCI CFG Write S_WR <= 1'B1; HIT <= 1'B1; end default: begin S_WR <= 1'B0; S_RD <= 1'B0; HIT <= 1'B0; end endcase end else if (current_state == S_BUSY_S) HIT <= 1'B0; end
//S_DATA: is register output, in order to mach CLK to PAD delay <7.8ns always @(posedge PCLK or negedge RST_N) begin if (~RST_N) S_DATA <= 1'B0; else S_DATA <= (next_state == S_DATA_S); end
always @(posedge PCLK or negedge RST_N) begin if (~RST_N) S_DATA_REG <= 1'B0; else S_DATA_REG <= S_DATA; end
//TAR_DLY: delete 1 clock wire #1 TAR_DLY = S_DATA_REG;
//Address Decode wire #1 ad_00 = (ADDR == 5'h00); wire #1 ad_10 = (ADDR == 5'h10); wire #1 we_en = S_DATA & S_WR; wire #1 rd_en = S_DATA & S_RD;
wire S_TERM = 1'B0; wire S_READY = 1'B1;
wire #1 RD_WR = S_DATA & (S_WR || (S_RD & TAR_DLY)); //assign #1 TRDY = !(RD_WR & (CFG_EN || S_READY)); assign #1 TRDY = ~RD_WR; //a optimize , add at 15/01/2002 //assign #1 STOP = ~(RD_WR & (CFG_EN || S_TERM));//1'B1; assign #1 STOP = ~(RD_WR & CFG_EN);//a optimize , add at 15/01/2002
wire #1 OE = S_DATA || TAR_DLY; wire #1 DEVSEL = ~S_DATA; assign TRDY_N = OE ? TRDY : 1'BZ; //tri gate output: is more slower assign STOP_N = OE ? STOP : 1'BZ; assign DEVSEL_N = OE ? DEVSEL : 1'BZ;
//CFG //CFG Address Decode wire #1 RD_ID = rd_en & CFG_EN & TAR_DLY & ad_00;//(ADDR == 5'h00); wire #1 RD_BAR0 = rd_en & CFG_EN & TAR_DLY & ad_10;//(ADDR == 5'h10); wire #1 WE_BAR0 = we_en & CFG_EN & ad_10;//(ADDR == 5'h10);
//CFG Write : BAR0 always @(posedge PCLK or negedge RST_N) begin if (~RST_N) BAR0_REG <= 12'B0; else if (WE_BAR0) BAR0_REG <= AD[31:20];//ADIO[31:20]; end
wire #1 WR_EN = we_en & ~CFG_EN ; wire #1 RD_EN = rd_en & ~CFG_EN & TAR_DLY ;
//PCI read data always @(RD_ID or RD_BAR0 or RD_REG or TEST_REG or BAR0_REG) begin case ({RD_ID,RD_BAR0,RD_REG}) 3'b001: AD_D = {24'H0,TEST_REG}; 3'B010: AD_D = {BAR0_REG,20'h0}; 3'B100: AD_D = {`DID,`VID}; default:AD_D = 32'B00; endcase end
assign AD = rd_en ? AD_D : 32'BZZ; assign P_L_DA = AD;
//PCI Interrupt Output assign INTR_N = INT ? 1'B0 : 1'BZ; //Tri gate output, need outside pullup res
endmodule
[此贴子已经被作者于2006-6-6 9:48:56编辑过] |
XHDL软件可以实现VHDL和Verilog代码转换!! |
