请教下面的VHDL代码,为什么地址线连不上???
请问下面的代码编译以后,为什么addr地址线总是连不上????
library IEEE;
use IEEE.std_logic_1164.all;
package instr is
 type instruction is (add, sub, lda, ldb, sta, stb, outa, xfr);
end instr;
use work.instr.all;
library IEEE;
use IEEE.std_logic_unsigned.all;
entity mp is
 port(instr : in instruction;
   addr : in integer;
   data : inout integer
end mp;
architecture mp of mp is
begin
 process(instr, addr)
  type regtype is array(0 to 255) of integer;
  variable a, b : integer;
  variable reg : regtype;
 begin
  case instr is --select instr to execute
   when lda =>
    a := data; --load a accumulator
   when ldb =>
    b := data; --load b accumulator
   when add =>
    a := a + b;
   when sub =>
    a := a - b;
   when sta =>
    reg(addr) := a; --put a accum into reg array
   when stb =>
    reg(addr) := b; -- put b accum in to reg array
   when outa =>
    data <= a; --output a accum
   when xfr => --transfer b to a
    a := b;
  end case;
 end process;
end mp;
这是怎么编译过的呢?
我这还有一个小程序,下面这个小程序段只是一个分频。但是编译总报错:error:line 22:file ......timer.vhd:unsupported feature error:non-locally-static attribute names supported.---不支持的特征错误:本地的静态属性名称不支持。
请指教。
 library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity timer is
port(clk:in std_logic;
s100ut std_logic);
end timer;
architecture arch of timer is
signal xishu120000:std_logic_vector(16 DOWNTO 0);
signal s100s:std_logic;
begin
fenpin:process(clk)
begin
if(clk'event and clk<='1')then
xishu120000<=xishu120000+"1";
elsif(xishu120000<="11101010011000000")then
xishu120000<="00000000000000000";
s100s<=not s100s;
end if;
s100<=s100s;
end process;
end arch;
把arch换个名字试试看
elsif(xishu120000<="11101010011000000")是不是有点问题?()中应该用==
美梦成真-->噩梦降临!
       elsifxishu120000<=xishu120000+"1";
这样再 看一下
    process ( clk ) begin
        if ( clk'event and clk = '1' ) then
            if ( xishu120000 = "11101010011000000") then
            else
            end if ;
        end if ;
    end process ;
