寄存器Verilog
寄存器Verilog
1。有异步清零端的n位寄存器:
module regn(D,clk,reset,Q);
  parameter n=16;
  input  [n-1] D;
  input  clk,reset;
  output [n-1] reg Q;
  always @(negedge reset,posedge clk)
      if(!reset)  //复位端reset低电平有效
         Q<=0;
       else
         Q<=D;
endmodule
2.D输入端有2选1多路器的D触发器:
module  mux_flipflop(sel,D0,D1,clk,Q);
   input  D0,D1,sel,clk;
   output reg Q;
always @(posedge clk)
     if(!sel)
         Q<=D0;
     else
         Q<=D1;
endmodule
3.四位一位寄存器:
/*当load=1时,让D的值赋给Q;当load=0时,寄存器向右移,right移入最高位Q[3];*/
module shift4(D,right,load,clk,Q);
    input  [3:0] D;
    input load ,clk,right;
    output  [3:0]  reg Q;
    always @(posedge clk)//注:这里的敏感信号只有一个clk,同步加载;
         if(load==1)
             Q<=D;
         else
         begin
            Q[0]<=Q[1];
            Q[1]<=Q[2];
            Q[2]<=Q[3];
            Q[3]<=right;
         end
endmodule
4.n位移位寄存器:
module shiftn(D,load,right,clk,Q);
     parameter  n=16;
     input [n-1] D;
     input load,right,clk;
     output [n-1] reg  Q;
     integer  k;
          if(load==1)
               Q<=D;
           else
           begin
               for(k=0;k<n-1;k=k+1)
                    Q[k]=Q[k+1];
               Q[n-1]=right;
           end
endmodule
5。四位递增计数器:
/*E为使能计数端,reset为异步复位端。*/
module upcount(D,reset,clk,load,E,Q);
     input [3:0] D;
     input reset,clk,E,load;
     output [3:0] reg Q;
          if(!reset)
              Q<=0;
          ele if(load)
              Q<=D;
          else  if(E)//注:这里的else是必须的。因为复位端reset优先级最高。
                  Q<=Q+1;
endmodule
6.递增/减计数器代码:
module updowncounter(D,clk,load,E,updown,Q);
     parameter  n=8;
     input [n-1] D;
     input clk,load,E,updown;
     output [n-1] reg Q;
     integer direction;
     always @(clk)
        begin
            direction=-1
            if(reset)
               Q<=0;
             else if(updown)
                direction<=1;
             else if(load)
                 Q<=D;
              else if(E)
                 Q<=Q+direction;
            end
endmodule
继承事业,薪火相传
