你要按照步骤来,:1. Install, copy sys_cpy.dll to C:\altera\quartus50\bin and overwrite the old one. 2. copy license.dat to c:\flexlm, then edit it: replace all '112233445566' with your true hostid. 在“开始”菜单中选择 "运行",敲入 CMD,然后在命令行窗口中键入 “IPconfig -all”,即可看到HostID(Physical Address) 3. start quartus, when asked for license, select c:\flexlm\license.dat [attach]2180[/attach] 如果还是不行,因为quartus的license以前行,现在可能不行了,你可以再继续找。
[此贴子已经被作者于2007-7-19 22:09:42编辑过] |
