library ieee; use ieee.std_logic_1164.all; --library bitlib; use work.bit_pack.all; entity static_ram is generic ( --下面给出的是RAM6116的时间特性值 --在本系统的组装中将被置为43258A-25CMOS RAM --的时间特性值 constant taa :time := 120 ns; constant tacs :time := 120 ns; constant tclz :time := 10 ns; constant tchz :time := 10 ns; constant toh :time := 10 ns; constant twc :time := 120 ns; constant taw :time := 105 ns; constant twp :time := 70 ns; constant twhz :time := 35 ns; constant tdw :time := 35 ns; constant tdh :time := 0 ns; constant tow :time := 10 ns ); port (cs_b,we_b,oe_b :in bit; address :in bit_vector(7 downto 0); data :inout std_logic_vector(7 downto 0) := (others =>'Z') ); end static_ram; architecture sram of static_ram is type ramtype is array(0 to 255) of bit_vector(7 downto 0); signal ram1:ramtype;-- := (others =>(others =>0)); signal flag:bit:='1'; begin ram :process begin --使用flag信号值对ram1清零,且只进行一次 if flag='1' then for i in 255 downto 0 loop ram1(i)<="00000000"; end loop; flag<='0'; end if ; if (we_b'event and we_b='1' and cs_b'delayed ='0') or (cs_b'event and cs_b='1' and we_b'delayed ='0') then --写操作 ram1(vec2int(address'delayed)) <=to_bitvector(data'delayed); --写操作完成后将数据读出 --data'delayed的值是data变为高前的值 data <=transport data'delayed after tow; end if; --置RAM为写模式 if (we_b'event and we_b='0' and cs_b='0') then data <=transport "ZZZZZZZZ" after twhz; end if; if cs_b'event and oe_b ='0' then --RAM未选中 if cs_b ='1' then data <=transport "ZZZZZZZZ" after tchz; --读操作 elsif we_b ='1' then data <=transport "XXXXXXXX" after tclz; data <=transport to_stdlogicvector(ram1(vec2int(address))) after tacs; end if; end if; --读操作 if address'event and cs_b ='0' and oe_b='0' and we_b='1' then data <="XXXXXXXX" after toh; data <=transport to_stdlogicvector(ram1(vec2int(address))) after taa; end if; wait on cs_b,we_b,address; end process ram; check :process begin if cs_b'delayed='0' and now/=0 ns then if address'event then --假定trc=twc assert (address'delayed'stable(twc)) report "address cycle time too short" severity warning; end if; if (we_b'event and we_b='1') then assert (address'delayed'stable(taw)) report "address not valid long enough to end of write" severity warning; assert (address'delayed'stable(twp)) report "write pluse too short" severity warning; assert (data'delayed'stable(tdw)) report "data setup time too short" severity warning; assert (data'last_event>=tdh) report "address cycle time too short" severity warning; end if; end if; wait on we_b,address,cs_b; end process check; end sram; 使用quartus 自动生成一个 sram 的描述,但是发现代码如上,怎么不可以综合呢 ? 难道我的设置有问题? |
