ERROR:iMPACT:477 - The bsdl for device 'UNKNOWN' is out of date. Please check your installation. ERROR:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File. INFO:iMPACT:1578 - '1': Device IDCODE : 00000000000000000000000000000000 INFO:iMPACT:1579 - '1': Expected IDCODE: 00000001110000100010000010010011 这个问题到底是什么方面的?cable还是电路,或者器件,看到好多人遇到这样的问题,但是就是没有具体的解决办法,在此请教高手帮忙,彻底解决这个问题!111111111 |
