我用ep1c12q240做ad0809的ad转换 仿真能实现我的功能 但是一配置到硬件fpga没有输出,状态机也不工作,问题出在哪里?fpga和ad的时钟都检测正常 状态机程序 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity adc0809 is port( clk : in std_logic; eoc : in std_logic; D : in std_logic_vector(7 downto 0); lock : out std_logic; ale : out std_logic; start : out std_logic; oe : out std_logic; addr : out std_logic_vector(2 downto 0):="000"; data : out std_logic_vector(7 downto 0) ); end entity; architecture func of adc0809 is -- Build an enumerated type for the state machine type state_type is (st0, st1, st2, st3, st4, st5, st6);
signal current_state,next_state : state_type:=st0; signal lock1 : std_logic; signal reg : std_logic_vector(7 downto 0); begin -- Logic to advance to the next state process (current_state, eoc) begin case current_state is when st0=> ale<='0'; start<='0'; oe<='0'; lock<='0'; lock1<='0'; next_state<=st1; when st1=> ale<='1'; start<='0'; oe<='0'; lock<='0'; lock1<='0'; next_state<=st2; when st2=> ale<='0'; start<='1'; oe<='0'; lock<='0'; lock1<='0'; next_state<=st3; when st3=> ale<='0'; start<='0'; oe<='0'; lock<='0'; lock1<='0'; if(eoc='0')then next_state<=st4; else next_state<=st3; end if; when st4=> ale<='0'; start<='0'; oe<='0'; lock<='0'; lock1<='0'; if(eoc='1')then next_state<=st5; else next_state<=st4; end if; when st5=> ale<='0'; start<='0'; oe<='1'; lock<='0'; lock1<='0'; next_state<=st6; when st6=> ale<='0'; start<='0'; oe<='1'; lock<='1'; lock1<='1'; next_state<=st0; when others=> next_state<=st0; end case; end process;
process (clk) begin if (clk'event and clk='1') then current_state<=next_state; end if; end process; -- Output depends solely on the current state
process (lock1) begin if (lock1='1' and lock1'event) then reg<=D; end if; end process; data<=reg; end func;
[此贴子已经被作者于2008-4-2 13:29:25编辑过] |
