modelsim出现的问题 菜鸟求问
modelsim出现的问题 菜鸟求问
用verilog编写的i2c功能程序在用quartus ii 7.0编译完成后,仿真工具里边选择verilog 调用modelsim进行门级仿真,但是提示我# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(218): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(250): Module 'stratixii_clkctrl' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(280): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(330): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(380): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(430): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(480): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(530): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(580): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(630): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(680): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(731): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(763): Module 'stratixii_clkctrl' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(786): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(818): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(850): Module 'stratixii_clkctrl' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(872): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(896): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(921): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(940): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(961): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(980): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1000): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1019): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1039): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1058): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1077): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1096): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1116): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1135): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1149): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1168): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1187): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1208): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1227): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1246): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1265): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1284): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1303): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1322): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1341): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1360): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1384): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1403): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1423): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1442): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1462): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1481): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1500): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1519): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1546): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1596): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1646): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1696): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1738): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1762): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1781): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1800): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1819): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1838): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1862): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1881): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1895): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1909): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1929): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1948): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1968): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(1987): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2007): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2026): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2046): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2065): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2085): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2104): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2124): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2143): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2162): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2181): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2200): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2224): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2243): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2264): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2288): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2307): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2321): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2340): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2359): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2373): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2393): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2412): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2432): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2456): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2480): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2504): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2529): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2548): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2562): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2581): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2600): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2619): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2643): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2668): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2687): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2706): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2731): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2750): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2764): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2783): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2802): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2821): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2845): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2864): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2883): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2902): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2921): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2946): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2965): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(2984): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3009): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3028): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3048): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3067): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3086): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3110): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3129): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3143): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3163): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3182): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3202): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3227): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3246): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3260): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3279): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3298): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3318): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3343): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3368): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3393): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3418): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3437): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3456): Module 'stratixii_lcell_comb' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3475): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3489): Module 'stratixii_lcell_ff' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3516): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3567): Module 'stratixii_io' is not defined.
# ** Error: E:/verilog/i2c/simulation/modelsim/i2c.vo(3617): Module 'stratixii_io' is not defined.
请教各位高手这到底是怎么回事?小弟不胜感激
[em01][em01]
综合工具你用的什么软件?可以试着换一下综合工具,然后再仿;
提示中的那些model都是些ipcore吗?
美梦成真-->噩梦降临!
