quartus ii6.0破解问题
quartus ii6.0破解问题
我装的是qaurtus ii 6.0,然后安装了quartus_ii_60_sp1_pc,
破解过程:将license.dat的hostid改为我的mac地址。
现在问题是:编译过程中出现“Warning: FLEXlm software error: Invalid (inconsistent) license key  The license-key and data for the feature do not match.  This usually happens when a license file has been altered Feature:       quartus License path:  D:\QuartusII\license.DAT FLEXlm error:  -8,523 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".”
请各位告诉我这是怎么回事。谢谢了
楼主可以到altera专区问一下,那里对quartus 比较熟悉
美梦成真-->噩梦降临!
我遇到这样得问题了
注册码怎么有好有坏的
Error: Current license file does not support the EP1S25B672C6 device
这个提示好奇怪
